profile grade break instead of vertical curve
Do anyone know where to find guidance on roadway profile grade breaks. It seems everyone i talk to has a different answer. I have a roadway with a design speed of 35 mph with a 100' sag curve. i want to get rid of the sag curve and replace it with a grade break but not sure if an AD value of 1.5% is Ok
RE: profile grade break instead of vertical curve
The number I've heard is 1% maximum on a grade break.
Why not use a shorter curve length, say 20' to 40'.
Some discussion at thread194-174877: Alley Profile Question
Generally, a maximum vertical grade break without vertical curve is limited to the 0.5%-1.0% range.  For instance, for a rural gravel road 1% may be allowable, but for a paved highway the limit is probably 0.5%.  The design speed and surface material are the two main factors that are considered in these requirements.
If it's a public road you should check local regulations. In these parts a vertical curve is required on public roads if the algebraic difference is 1% or more.
