copy the parameters file out to an external spread sheet.
Can anyone advise me how to copy the parameters file out to an external spread sheet.
Inventor seems to expect you to create the spread sheet prior to making the component whereas I would like to accept the existing parameters file with the ability to alter a few of the measurements.
I am a die-hard MDT trying my best to get to grips with inventor.
Many thank,
cjj
Many thank,
cjj
RE: copy the parameters file out to an external spread sheet.
On the ribbon go to the manage tab. Expand the flyout under the Parameters icon. Select "export to xml".
Then import into excel.
I was running Inventor 2009 to go along with the latest version of MDT 2009. However, I do have Inventor 2011 and cannot believe just how easy the export route was.
Presumably any mods I make to the xml file if imported back into my drawing will drive the model?
Thank you so much, this simple advice has saved me possibly a day of work.
cjj
