31.1 or ASME SEC I ???
can someone explain me the main difference between the standard 31.1 and the ASME SEC I... i´m very confused with them...
yours truly JM
RE: 31.1 or ASME SEC I ???
One applies to pipe and the other to pressure vessels.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Adding to vpl's response: Sec 1 is for power boilers.
Both codes include graphics that clearly define their jurisdiction.  Look around page 41 in Sec I and page 2 in B31.1.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered.  It is offered with the understanding that the author is not engaged in rendering engineering or other professional service.  If you need help, get help, and PAY FOR IT.
You can also reference the Section I Preamble and PG-58.
There is an overlap of the two codes in regards to Boiler External Piping, where B31.1 has technical jurisdiction while ASME I has administrative.
juliomendez,
The main difference between the standard 31.1 and the ASME SEC I is one is about "small and fat and always boiling" (ASME Sec I), and another is about "round and very lo-o-ong" (B31.1).
Now, you won't be confused anymore.
Curtis
asme extends from the boiler to the first valve/weld outside the boiler where 31.1 takes over.
