Marine Growth in Stagnant Piping
Does anyone know of any guidance for determining expected amounts of marine growth inside normally stagnant shipboard piping that is open to seawater?  I expect that the amount of growth is at least somewhat dependent on the piping material, since some materials are considered repulsive by the little critters.  So, maybe I can avoid marine growth altogether with the right material?
RE: Marine Growth in Stagnant Piping
To: Mpisani;
Your posting is from 31 July 2002
Still hope to serve you with:
Copper-Nickel is probably the chosen metal.
See the links:
http://www.nidi.org/index.cfm/ci_id/10649.htm
A technical explanation can be found at:
Marine Corrosion Forum
http://www.marinecorrosionforum.org/tpjul02.htm
See Point 8.2 CuNi90/10 for sea water service.
And in a Forum we can make furher directed postings!
A good explanation in .pdf: AustralWright Metals,
10 pages (April 2001) See pages 3 & 4. Link:
http://www.australwright.com.au/DataSheets/Advice/Coppe...
Hope you have some "fruit" out of this.
Still to: Mpisani (and hopefully many others);
CORROSION:
Just by chance I got the following very relevant link:
LaQue Center for corrosion technology Inc.
(Queries? info@laque.com)
URL: http://www.laque.com/testing/coatings.htm
Use a hypochlorination system.
you may want to read about a growth suppression system made by a company called wilson walton.
www.wilsonwalton.com
MARINE GROWTH:
The strength of a Forum lays in the responses generated!
Many thanks to: (among others!)
thijsie (denkelijk een Hollandse jongen)
ssreese1500 and MP21
If anyone doesn't need a feedback himself, it is always worth to have an input for anyone else!
This is what I appreciate.
Cordial greetings.
