API 12F vs. API 650 and anchors
Using a 210 BBL, design pressure of 16 oz. from Table 1 of API 12F, OD is 120" and height is 15'. Floor is 1/4" thick, shells are 3/16" and roof is 1:12 slope and also 3/16" thick. I chose a 210 BBL as the floor and shell thicknesses would be equivalent to an App. J tank of API 650.
I am well aware the that the roof geometry b/n these codes are different, but my issue is with F.4.2, which is independant of any roof compression areas and slope. Applying F.4.2 to a 12F tank provides a Pmax of around 0.5 ounces. API 650 wants this tank anchored.
Can anybody shed light on the mentality behind the formula of F.4.2? A positive pressure (increase in design P) is available due to shell weight, roof weight (0.08 * th) and is decreased due to the wind, which leads to anchorage.
Assuming the tank is fixed at the floor, call it liquid level which stops any deformation of the floor, the tank is essentially a cantilever with the wind as a load. Stress due to wind on the shell are minimal in this scenario.
Does J.3.9 intend to ignore F.4.2 and simply worry about overturning moment due to wind?
This issue pertains to purchasers specifying API 650 tanks when API 12F will work.
RE: API 12F vs. API 650 and anchors
