How to run a Subroutine
To run a T.INP file in ABAQUS/Standard I use the following command:
Abaqus job=T datacheck interactive
Then
Abaqus job=T continue interactive
Can somebody advise how to run a INP file which has subroutine FRIC (when I use the above commands it errors)
RE: How to run a Subroutine
You have to include the "user=filename.f" at the end of the command.
Thanks for reply,
Just as an exercise I wanted to run ABAQUS example (ABAQUS Verification Manual , Sec. 4.1.4, ufricxxx.inp   and its subroutine   ufricxxx.f   as attached) with the following command
Abaqus job=ufricxxx user=ufricxxx.f
But it gave error command saying "the following files could not be located ...."
Any advice?
If you're working with Windows the extension for the Fortran file is .for not .f
Again error,
Do I need Fortran on my PC to run subroutine?
Yes.  Refer to the ABAQUS installation guide.
