Buckling length problem
Hello!
I am trying to calculate a steel structure using the Finnish standard B7. In my calculations I need the lower chord of the roof trusses to be designed based on an unbraced length of 14m on Y direction, and on the member length on Z direction. Is it possible to define these lengths? I tried to use the LY, LZ parameters but the message that I get is "Steel design parameter is not supported with NS 3472 code" ... And btw, the NS3472 code is a Norwegian steel design code, and I have no idea why it appears in my calculations ...
Thank you very much,
Cris
Cris
RE: Buckling length problem
