Trawl winch
Trawl winch
Trawl winch
Can someone tell me why a large majority of design company preference electrical winch over hydraulic winch in fishing vessels?
thank for help..
RE: Trawl winch
Because hydraulic fluid (from inevitable leaks) tastes lousy.
RE: Trawl winch
This i know.
Also we do not need power pack that takes space. People don't need so much experience in electrical equipment. Towing power in hyrdaulic and electrical equipment is now almost the same.
Do you have any other ideas?
RE: Trawl winch
The answer you got was complete and coherent.
What problem are you trying to solve?
Mike Halloran
Pembroke Pines, FL, USA
RE: Trawl winch
it's apparent electric is preferred. fishing vessels don't have a room for power packs or hydraulic aggregates units, hydraulic lines, etc for hydraulic winches that complicates the installation space and maintenance issue, however; the latter simply motor and cable laid on deck, straightforward and simple. that's it
"..the more, the merrier" Genghis Khan
RE: Trawl winch
Thanks.
RE: Trawl winch
laying an electrical wire on a fishing boat is a bad idea.   Proper marine construction would call for running the conduit under deck and up through a penetration in the way of the motor.
Hydraulic systems have more components and require more expertise to operate than finding a bad wire or changing out a bad motor, but one of the main reasons for an electric system is that an oil spill can cause up to a $50,000 dollar fine from USCG
