Footings & Load Factors
I seem to come across an issue a lot that I don't know what to do with.
Often when checking bearing pressure under service loads I have no uplift across the footing. As soon as I factor my loads though I do get uplift.
In other words, the load factors change the structural support. The concrete design loads are now based on a an altered support condition influenced by load factors. This doesn't seem like a realistic approach to me. Any comments or thoughts?
RE: Footings & Load Factors
Adam Vakiener, P.E.
That approach seems a little conservative, but reasonable to me. Any other ideas anyone?
i encountered a similar thing about tension load.
load combination was allowable.
tension reaction was say 20 kips.
another engineer's calcs, he multipied the tension to 1.6 to make it ultimate or factored.
That summarizes my question very well. Am I after the factored loads, or the factored load effects?
And I don't agree with simply multiplying unfactored bearing pressure by 1.6. This can be unconservative sometimes.
DaveAtkins
Also, you couldn't be looking for the factored load effects because you'd have a different support condition for dead, live, wind, etc. and you can't just find the effects of each one and add them together. You have to combine the loads somehow before you find the load effects.
