Confused By Apparent Slip Agent in ABS
Hello All,
We are pad printing a company logo on some ABS Bayer Lustran 348.
We are having trouble getting the pad printing to stick to the part (after the ink cures, it can be removed with a fingernail) and we have identified (via FTIR) a fatty acid most like Erucamide. According to Bayer, this "slow bloom slip agent" is not an ingredient in their ABS base material.
To combat this Erucamide (which propagates to the surface of the part over time), we are wiping all the plastic parts with Isopropyl Acetate prior to printing in an attempt to remove the surface contaminant.
Do any of you have experience with Ercuamide (sources of and techniques for removing it)?
Thanks!
- Josh
Thanks!
- Josh
RE: Confused By Apparent Slip Agent in ABS
How did it get there is Bayer didn't add it? Is that a component of for example your mold release spray?
Be careful wiping ABS, solvent can destroy it via environmental stress cracking.
First check to make sure what your mold release is. After all, that is a chemical designed to prevent adhesion.
Get another grade from another company, Dow or BASF.
There are additive that improve adhesion, contact for example Cray Valley (Jeremy Austin is my contact person there).
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Firstly, to answer your question, we are a medical device manufacturer and mold release is not permitted on our product; the "no mold release" statement is noted on our drawings (I even have a signed letter from the president of the molder we work with that states no mold release is introduced).
Yes, I am stumped where this surface contaminant is coming from. I did query lustran-polymers.com and they relayed that Erucamide is not within their formula. They did state that Lustran ABS 348 contains an external lubricant "AWAX" (a.k.a. N'N Ethylene bisstearamide); perhaps that is what is giving us the trouble.
Your advice to try another supplier makes sense and I will definitely look into additives that promote adhesion (I assume these additives are mixed in with the base material).
Again, thank you very much for your reply; I appreciate it.
Unless it's a smaller shop with a CEO who works also at shop floor level regularly, despite what company CEOs like to think, once it gets down to shop floor level, staff do break procedures at times if it makes life easier for them.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
I also realize this might be what Pat was getting at.
I'll keep your advice about CEO vs. Shop Floor in mind as well, Pat. A site visit to the molder is an option.
prdave00, yes, as these are medical devices, regrind is not permitted. Your thought about cross-contamination in the hopper is a great one and I will follow up on that.
I would estimate that our losses in production scrap and time spent on this ink adhesion issue are in the tens of thousands of dollars at this point. We are very interested in finding root cause and I thank you all for your help.
Pat
for site rules
www.tynevalleyplastics.co.uk
Let me know what you find out. I'm interested since the mold shop we contract with for our some surgical instruments has used Compounding Solutions for their needs (including adding barium sulfate to Lustran). I guess there is nothing barring them from using pigments/additives containing fatty acids (unless CFR Title 21 explicitly prohibits it), but it would be nice to find out what's in the compounded resin to also support biocomp data.
I had some parts shot from natural Lustran 348 resin. The attached file attempts to show the off-white color of it against a white background. I'm also aware that INEOS offers a Sno-White color. Have you considered switching to a resin that isn't compounded by another supplier? I guess it might be too late if your trying to save an existing batch.
The effect occurs in all ABS but in some types it's less of a problem than in others. I just presented on this very topic in a webinar yesterday (for SpecialChem).
prdave00, I'll surely keep this thread updated with the findings and thanks for the photo of the natural Lustran 348. I did see that INEOS offers the "sno white" color and this would be a good option to relay to our customer once the ink adhesion benefits are proven out.
I'd be very interested in shooting some samples with a resin that isn't compounded (the molder that we work with has also said they would support this activity).
Would I obtain this sno-white Lustran 348 directly from INEOS or another supplier?
Dr. DeArmitt, concerning the mechanics of the parts, we ultrasonically weld them together after pad printing, so I am interested to see how the weld results of our current compounded material compare to unadulterated, un-compounded material.
Again, I thank you all for your time and expertise. This is great information.
Pigment in the ABS acts the same as filler and lowers the impact resistance significantly.
Are you interested in "snow white" ABS because it would be pure, without additives? In that case don't bother. Pure, uncolored ABS is a beige colour, not white. Any white ABS you buy has had TiO2 pigment added and so it could have your unwanted wax present because TiO2 is often added in a masterbatch containing waxes and dispersants.
You should heed Chris's warning and make sure that fatty acids like Erucamide aren't being introduced in the compounding of their "sno-white" colored offering. There probably is a very good chance that pigments like titanium dioxide (TiO2), Ti-Pure R-101 for example, are added. I say better to be safe than sorry, so I would call the INEOS and confirm specifically about it. That resin may pass the "medical grade" test but not the pad print test.
Per their data sheet: "Lustran® ABS 348 resin is an injection molding grade of ABS (Acrylonitrile butadiene styrene). It is a medium impact, high-gloss ABS, available in natural (000000), snowhite (012002), and selected colors."
I know that as I worked on that topic for some years at BASF who make ABS.
