EN24 Rockwell Hardness
Hi, I am soon going to be rolling some threads from EN24 bar before having them heat treated. Looking at page 10 of this pdf http://www .landisthr eadingsyst ems.com/Th readRollin g/Library/ TechnicalS upport.pdf how should I know what column I should be referring to? They refer to material hardness, which I am unsure of. EN24 is equivalent of SAE 4340. The threads will be 7/16 unf and unc.
I am also getting myself confused between the difference in class 2 and class 3 shown on the same page.
RE: EN24 Rockwell Hardness
Thread Class refers to the tolerances and allowances (i.e. slop). Class 1 thru 3 get progressively tighter. Its all defined in American National Standard Institute (ANSI) B1.1, titled 'Unified Screw Threads'. There are probably online calculators, but here's an example.
.4375-14UNC-[what the class is]A ('A' means external.)
EXTERNAL Class 2 Class 3
Major Dia 0.4360 +.0000 - 0.0103 0.4375 +.0000 - 0.0103
Pitch Dia 0.3896 +.0000 - 0.0050 0.3911 +.0000 - 0.0050
Minor Dia 0.3587 Max, Ref 0.3602 Max, Ref
.4375-20UNF-[class]A
Major Dia 0.4361 +.0000 - 0.0081 0.4375 +.0000 - 0.0081
Pitch Dia 0.4036 +.0000 - 0.0047 0.4050 +.0000 - 0.0047
Minor Dia 0.3820 Max, Ref 0.3834 Max, Ref
Depending on ruling section and heat treatment it can achieve 100 T/in2, "condition Z".
We use condition T for shafts.
Can I assume that some of the information I will been and have been using is slightly complicated by the fact that the EN24 info is UK based whereas most of the thread rolling etc info is US based?
I don't understand your last question, but if you want information on thread rolling that is from a European company, LMT Fette will have standard sizes, etc. for metric threads:
http://w
There is a BS for unified threads, I was going to say 1936 but I think that's undercuts for unified threads.
www.boltplanet.com has a calculator for unified threads which can be useful to check your own calcs.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
However in the late 1960's the UK started looking East to Europe and metricated.
