Question about finding Equivalent lenghts
I'm new to the engineering world and trying to find how to express the answer on paper. What is the pressure loss on this pipe assembly;
3/4 tap on water main
1" corporation stop at water main
28ft of 1" copper tubing
1" curb stop
68ft of 1" service line (plastic)
1" 90 degree bend
1ft of 1" copper pipe
1" gate valve
22 degree bend
5/8 X 3/4 rotating disc meter
15ft 3/4 garden hose
discharging into open air.
Static pressure is 45psi at tap on watermain
Thank you for any help!
1" curb stop
1" 90 degree bend
1" gate valve
22 degree bend
RE: Question about finding Equivalent lenghts
Flow of Fluids Through Valves, Fittings & Pipe TP-410 by Crane Valve
