Pro/Mechanica Examples
Could someone please guide me in the direction of some Pro/Mechanica examples. I am having a number of problems if anyone can help I would be very grateful.
1) How would I best model an adhesive layer? It seems to have problems creating the element with AutoGEM.
2) Can you change the mesh density and what effect does it have?
A Beginer!
A Beginer!
RE: Pro/Mechanica Examples
http://kahuna.sdsu.edu/~johnston/ME1_2001.pdf
Adhesive Layer: What I would do, is not draw the whole component(with the adhesive layer) as one part file. I would draw the component seperately, and the adhesive layer separtely and assemble them in assembly mode. Then what you could try is to play around with ''Joints and Connection'' and probably bond them. Now this is just a suggestion. Do ask someone.. The best way to model adhesively bonded joints would be in ABAQUS..
Hope this helps.
