Problem with swbrowswer.mdb in Solidworks2010
whenever i click in Hole Wizard on the Features toolbar, I get the following error:
Error: could not find Standards database 'Solidworks\Data\lang\english\swbrowswer.mdb'
Any suggestions?
RE: Problem with swbrowswer.mdb in Solidworks2010
When you browse to that location, is the file there?
Search for the file, and either move it to the location specified, or re-specify the found location in the Tools > Options > System Options > File Locations section.
Is "G" a local or networked drive/directory ?
Have you searched for the swbrowser.mdb file there ?
It´s local. Yes, and i couldn´t find it.
When at the screen in your image, when you click on the Configure button and select option 2, do you see something like the attached image?
If yes, the swbrowser.mdb file exists at that location.
If not, you may have to do a repair from the SW install DVD.
If that doesn't work, then a complete clean uninstall and re-install may be required.
