Generator Proximity to Building
Does anyone know of a specific code that indicates minimum distance from a building for Generator?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Generator Proximity to Building
There may be some issue regarding the location of the fuel storage, assuming this is a diesel generator. This may also depend on the occupancy and the fire rating of the walls.
Noise.
Discharge of exhaust and proximity to any air intake points for the building.
Fuel Storage and fire rating as per dpc's comment.
Access for servicing and maintenance.
Access to operate the unit (I'm assuming from the question its a standby generator).
Cheers,
Dave
David Castor
www.cvoes.com
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
Rafiq Bulsara
http://www.srengineersct.com
