Mapkey which has a copy "file_name"
I am just starting the adventure with ProE, and I need help.
I must to create mapkey, which will copy the name of the active part, for example click file->rename-> them copy file name->close, or some other way.
It would be great if mapkey to write the name of the txt file,but not required I can do it manually.
