Required: foundry to supply casting & U-2 form
Hi All,
Has anyone knowledge of, or experience with, a North American foundry that can supply a one-off, custom, non-standard pressure part, complete with a Manufacturer's Partial Data Report or U-Stamp, for a SA-351 CF8M casting (~110 lbs)? The casting is to be a component of a registered VIII-1 pressure vessel.
Qualified foundry names, phone numbers, or web links gratefully received.
Howie
Howie
RE: Required: foundry to supply casting & U-2 form
The second link is to a service company that has the connections to get you component made.
Either company should put you on the right track if they no quote. Watch out for long lead times and in the same vain don't expect overnight service.
http://www.waukeshafoundry.com/#/AboutUs/ContactUs
http://www.metaltek.com/
