Chlorine attack
Chlorine attack
I have some water tanks in which the water will have a Chlorine level of between 3 and 4 ppm (3 to 4 mg/litre)
The pressure in the tanks will be between 10 and 40 Bar and they will vary in size from 2 cubic metres to 40 cubic metres.
I have been asked to line the inside of the tank with butyl rubber, but looking at some web-sites it seems to me that the butyl rubber will be attacked by the Chlorine at this level of ppm, and have a short life (I know butyl is ok at lower Cholrine concentrations, say 0.5ppm).
Can anyone suggest an alternative rubber compound that will resist the Chlorine, and not cost the earth ?
Also, we would normally use a level gauge made from stainless steel, but I am uncomfortable with stainless steel at this chlorine concentration for the pressure the tanks are to work at - am I right to be worried ?
Thanks for any help.
RE: Chlorine attack
Have you looked at using, instead of a rubber lining, an internal coating of epoxy, i.e. 'Plascite'?
RE: Chlorine attack
Don't worry about a stainless steel pressure gauge. As Duwe6 wrote, the chlorine concentration is less than in typical potable water.
RE: Chlorine attack
There are many proven epoxy coatings that will do well in this service,
