Quadro FX580
Quadro FX580
Hi All,
I've got the following configuration:
DualCore Intel Core i3 570 (3,06 GHz)
Gigabyte GA-P55-US3L
Kingston 2x2 GB DDR3
Nvidia Quadro FX 580 (with latest driver)
Op: Win7
My problem is the Solidworks 2009 is very slow on it. I tried different driver, setup, but nothing helped.
Shall it cause the wrong hardver pairing or wrong setup?
Thank you in advance!
Philip
Op: Win7
Philip
RE: Quadro FX580
Latest driver from nVidia site or latest approved driver form SW site?
Did you uninstall the old driver and reboot before installing the new driver ?
Op: Win7
Home, Business, Ultimate ?
X32 or X64 ?
How slow is "slow"?
How does your time compare to the benchmark tests at
htt
http://www
RE: Quadro FX580
What did you have for computer specs before this one that worked well?
What are you designing in SW? Big assemblies, somthing with a lot of surfaces, or smallish parts/assemblies?
Check your driver first for make sure it is an the approved driver list for your card.
http://www.solidworks.com/sw/videocardtesting.html
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2011 PR1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
RE: Quadro FX580
That processor will likely never be a screamer for SW. It was designed as a low pwer, low cost, low end cpu from Intel.
For SW performance you want to be looking at Core i5 at a minimum and Core i7 fot best performance.
http://en.wikipedia.org/wiki/Core_i3#Core_i3
Cheers,
Anna Wood
RE: Quadro FX580
Op: Win7, Prof. X32
Benchmark test (Total rebuild time):
Punch holder: 100,73 sec.
204457, Carrier: 44,96 sec.
My problems are the following:
- When I open an assy. with 2 simple (i.e. 2 rings) parts and I want to expand the tree the program thinking about 3-5 sec. when do this.
- When I want to modify the sketch and changing the display style it doesn't refresh.
Philip3
RE: Quadro FX580
Anna Wood
RE: Quadro FX580
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
