Fluid-Structure Interaction
I want to model a container poured with water and I want to exert an earthquake record to the container and find the fluid behavior. My problem is I do not know why fluid and container does not have any interaction while I use Abaqus explicit Default contact. It means that water will exit from the bottom of the container.
Your kind assistance are appreciated in advance!
RE: Fluid-Structure Interaction
http://
its the 3/10 Abaqus 6.10 for Unified FEA, that may help. The also have a FSI-Explicit exmaple there too.
Hope that help you
Nagi Elabbasi
www.veryst.com
I'm looking to the same pb can help too
