Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...just the few hours I've spent on this site I have learned a lot. I can now implement features that will be very useful to my company, and some of those I never knew existed..."
Geography
jerryv (Mechanical)
15 Oct 10 15:50
Paint Specification
My company like many other machines manufactures supplies our equipment with standard paint colors.  Over the years we have been able to work with our vendors to provide paint color that is uniform throughout paint types and processes.  However we have the occasional customer that requires a specific paint color (RAL).  Whenever we change form our standard paint color to a non-standard color we run into problems with color differences.
Can anyone provide an example of a paint specification which if given to a vendor, no matter the coating process (Powder, Enamel or Polane spray) we can consistency receive paint that matches?
Since we utilize foreign sourcing we would prefer that the specification not be brand specific.
I have attached an example of our standard paint specification but as you can see it is specific to Sherwin-Williams which may not be readily available in all areas of the world.
KENAT (Mechanical)
18 Oct 10 14:56
Isn't that the point of having the RAL number (or Pantone or FED STD 595B or similar?
For critical applications we'll sometimes supply 'paint chips' for them to match, and/or have them send us 'paint chips' for us to approve.
If someone has a more complete answer I might be interested too.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
IRstuff (Aerospace)
18 Oct 10 15:23
Just to echo Kenat's posting, FED-STD-595 is actually a series of color samples, e.g., 36320 is a battleship gray, and when you ask for the specification, you get a 3" x 4" swatch of paint on cardboard.
TTFN
KENAT (Mechanical)
18 Oct 10 17:36
RAL & Pantone are similar IRstuff, RAL is German in origin I can't remember for Pantone but it's a commercial standard.
BS391C is the British equivalent to the fed std.
One problem is that certain industries and or geographic use different specs, and there isn't necessarily a direct correlation - maybe on the fed & BS but not on the commercial ones.
IRstuff (Aerospace)
18 Oct 10 18:11
My understanding is that Pantone, ostensibly, has a correlation with colorimeter measurements.  At least, they have instrumentation that they sell for calibrating color monitors to ensure that the color you see on the monitor is consistent with the RBG definitions in the image files being displayed.
TTFN
IRstuff (Aerospace)
18 Oct 10 18:14
And in general, that's something that is doable, given the relatively low cost of a decent colorimeter.  One could, for example, take the FED-STD-595 color swatch that I have and scan it for its color coefficients and require that the paint supplier be capable of producing that color with their paint, and can maintain that color to within some tolerance over time and environment.
As far as I know, no one in the military goes to that level, but that's possibly due to the severe environments that the paint goes through, not even counting the mud and muck, etc.
TTFN
KENAT (Mechanical)
18 Oct 10 18:50
I don't think anyone in the military goes to that effort, I've seen many and varied shades of 'saxe blue' on the same equipment from different production batches.
The colors that have meaning, such as on explosive stores, are chosen to be far enough apart from each other that even allowing for poor matching, fading etc. they are still differentiable.
So 'Saxe Blue' for flight worth practice stores which may have low explosive in them, is a long way from 'Oxford Blue' that should be totally inert, ground use only, drill rounds.
The coloromiter should get you most of the way there but I don't know how the other visual effects play into things.
KENAT (Mechanical)
18 Oct 10 19:09
Just realize I my have slightly misunderstood, pantone also sell color swatches like the fed std one.
Close Box
Join Eng-Tips® Today!
Join Us             Close
