A529 GR 50 cracking after galv
Angles welded to tubes then galvanized. The angle its self cracked/tore near the weld. We replaced the angles and the same thing happened. The 3rd time we replaced them with A572 GR50 and they didnt crack. What would cause this? Does the welding then galv process not work well with the A529?
RE: A529 GR 50 cracking after galv
