Workbench Solid Materials
I'm using Workbench 12 and importing the geometry via an iges file. The imported object as several bodies. I've also selected 2 materials in the engineering data window. What I would like to do is assign each body to a one of the two materials. It appears Workbench assigns the default material to all the bodies. Is there a way to assign each body it's own material?
Thanks for any help.
RE: Workbench Solid Materials
Thanks!
