Problem running example problems
Hi, I have been using the abaqus example problems manual because some of the examples are actually quite similar to what I would like to do.
The problem is that for some reason when I load the input files into cae and then create a job and let it run, the solver always crashes with an error.
But when I create a job straight from the input file and not from the cae environment there are no problems.
It is really weird.
Does anyone know what the problem may be?
It is really weird.
RE: Problem running example problems
It's also strange that when I look at the BC's and steps they don't seem to complete, for some reason when I load the input file into cae its missing things, but when u load it into the solver directly it works. I really don't understand why.
