how to define contact in axisymmetric model
cross-section of a revolved structure, modelled with 2D axisymmetric parabolic elements.
There is a gap between the two parts. Model is in global XZ plane, gap between parts is oriented in vertical direction so contact should be found in x direction.
I've tried slide lines and gap elements within an advanced non-linear analysis, but nothing seems to work, the faces penetrate without any reaction.
can anyone give me some tips?
RE: how to define contact in axisymmetric model
The problem lies in a sort of bug in Femap. Below I summed all information.
Thank you Namklof for your reaction. I knew about the springs but needed real contact element.
Siemens made a Problem report that will be solved soon (high priority):
FEMAP is incorrectly writing out the slide line contact for a 601 solution. The Nastran 7.0 QRG, page 1009, Remarks related to SOL 601, remark 6, says that contact for SOL 601 is defined using a BCTSET entry instead of the BCONP entry. The deck written by FEMAP 10.1.1 is lacking this entry.
As a work around the user may do the following:
Add this line to the bottom of the case control section, just before the begin bulk line:
BCSET = 100
Then add this line at the very bottom of the file just before the ENDDATA line:
BCTSET,100,2,1
This can be done via the edit preview functionality.
It's 2010 people. Time to progress.
tg
