Sulphuric Acid material selection
I would be interested to get confirmation on the following:
I have an application with 99.2%wt% H2SO4 at 30.4C and believe that using 316 Stainless Steel metal parts is suitable. Can anybody confirm this material selection?
thank you in advance
RE: Sulphuric Acid material selection
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
304L looks good.
Plymouth Tube
