Reducing Cooling Drag on a Stemme S10
Hey Guys,
Im trying to reduce the cooling drag on a Stemme S10 by modifying the cooling ducts. However I am having trouble coming up with ideas. I was going to try to use a NACA duct initially but the surface of the airplane where the engine is located is at a negative slope to the airflow. If anyone has any ideas on how I would be able to use a NACA duct or any other ideas on cooling the engine, it would be much appreciated. I have enclosed a picture for reference.
RE: Reducing Cooling Drag on a Stemme S10
Unless you are having problems with the engine overheating, I would leave it alone. The cooling ducts retract when the engine is shut off and the propellor is retracted.
They stick way out into the airflow, because they are, sited in a turbulent region.
B.E.
Look at first diagram, shows an offset inlet duct, the idea is to move the inlet out of the turbulent boundary layer. The result is more flow (more total pressure) per square inch of protruding cross section, i.e. you can reduce the duct area quite a bit because the intake sees very little retarded flow from the boundary layer, and thus can lower drag. P-51 Mustang used similar ducting, which (due to heat addition and good exhaust flow ducting of the radiator stream) actually added net thrust to the airframe.
I agree with berkshire...which is the object to modify the inlets and exits of refrigeration system ? these are open
only whe you are going to start up the engine. In this condition the saving is immaterial on cooling drag since
the engine delivers necessary energy to fly.
It justifies an extensive modification of the system for any small saving ?
The Rotax used in Stemme is a turbocharged engine. I think is mandatory mandatory to assure a correct refrigeration to the turbo .Also to the intercooler, oil cooler,radiator, etc).
Best Regards
The cooling systems that you showed me are for when the engine is in the front of the fuselage. Would this work for an engine behind the cockpit? I'm not sure where all the airflow is turbulent and what effect the prop has on the air.
In reality, do a flat plate b.l. calculation for the speed of interest, and find the 90% momentum thickness, use that value for the inner edge of the intake ramp.
I'd be taking total pressure profiles across the current inlets, and possibly at a few outboard stations as well, to guide the effort. Data beats calculations every time.
