Post-Installed Anchors
Does anyone know if AASHTO permits the use of post-installed anchors such as epoxy anchors or drilled in type anchors for anchorage to bridge decks?
I posted this question in the bridge section but this forum is much more active.
RE: Post-Installed Anchors
Does your state DOT have a standard sheet? The Minnesota DOT LRFD Bridge Design Manual - free download - has an example of metal railing with adhesive anchors in Chapter 13.
