How to model a oneway slab in ETABS?
1)How can I model a simple oneway slab in ETABS?
2) I have long spans in my slab and I should use truss or steel joist under the slab how can I model my slab in ETABS?
RE: How to model a oneway slab in ETABS?
first go to the define wall/slab section
then go to the slab
theres a box there that you can pick if you want a one way slab
and you can orient it too
try to have a manual and you will see different ways on making slab
Poems are made by fools like me, but only God can make a tree. engineers creates wonderful buildings, but only God can creates wonderful minds
I would use a membrane element (no out of plane stiffness). This will force all the load to be transferred to the supporting element.
I have not had much success with using one way distribution of shell element forces, especially if it is non-rectangular.
yes, dont forget to choose the membrane box in the program if you are modeling the slabs
but of course, before using the resulting forces, try to provide a manual rough calculations so that you will know if the program is doing what you want it to do....garbage in garbage out
