Distribution Transformer Name plate information PCB
I am trying to find a picture of a distribution transformer name plate. Do they exist? Can you read them anymore? Most importantly can you take a picture from ground level to record this information. I am looking for information that pertains to PCB concentrations. Any help on this would be greatly appreciated!
RE: Distribution Transformer Name plate information PCB
I am looking for a utility pole mounted transformer name plate.
You can photograph a nameplate if you can get in the right position and have a good enough camera lense. Your typical point-and-shoot camera won't hack it.
or search the web, for example: http://
or take a walk along a street near you with pole mounted transformers.
Rafiq Bulsara
http://www.srengineersct.com
Utilities are required to know the PCB status of their equipment, so usually the test stickers are a better indication. In practice, if you don't see a PCB test sticker, you can pretty safely bet that the nameplate says non-PCB; otherwise there would be a test sticker.
