Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
...I enjoy spending time on it for personal growth (I learn from the questions I don't answer, and I reinforce/stay sharp on the topics I do answer), and to give back to humanity at large...
Geography
Electrolytic capacitor ESR at DC (Zero Hertz)Helpful Member!
schnell (Electrical)
14 Oct 10 8:56
Hello , this capacitor's ESR is 0.141R at 120Hz.
(Rubycon TLV series , 1.5mF, 16V)
-but do you know what is its ESR at DC (Zero Hz) ?
Datasheet as a file download:-
http://www.2shared.com/document/YEIECZh3/T...ic_capacit.html
Datasheet on web:-
http://www.rubycon.co.jp/en/catalog/e_pdfs...roducts_Eng.pdf
Helpful Member!  Skogsgurra (Electrical)
14 Oct 10 9:49
That is something that you can't measure - or even talk about. Even if you use the standard test method, discharge through an external resistor and calculate ESR from the initial negative voltage pedestal, that ESR is a result of the frequency spectrum contained in your discharge current and does not represent the DC ESR.
In other words, there is no such thing as DC ESR. And if it existed, you could not use it for any practical purposes.
Gunnar Englund
www.gke.org
benta (Electrical)
14 Oct 10 10:12
Don't quite understand the background for this question, but I could imagine the OP perhaps sees unexplained DC shift on the cap.
That's not an ESR issue, but dielectric absorption or "soakage" as National calls it.
Benta.
benta (Electrical)
14 Oct 10 10:13
VE1BLL (Military)
14 Oct 10 10:19
Perhaps one could determine the ESR at various frequencies and extrapolate the curve to zero Hz.
14 Oct 10 10:29
That would be an interesting excersise for a rainy day! If I know myself, I will probably do it in a near future.
Thought: Put DC on the capacitor and superimpose a square wave. FFT voltage and current. Calculate ESR at different frequencies from ratio Un/In, where Un and In means voltage and current value at the harmonics found.
That would also show if ESR varies with frequency or not. Has to be careful, though, so ESL doesnt show. That would ruin the measurements.
Gunnar Englund
www.gke.org
14 Oct 10 10:48
the reason for asking is that this capacitor will be charged up and then used to actuate a solenoid valve by discharging it through the coil.
...so its essntially DC.
But i fear that the Zero Hz ESR may be well high and poorly toleranced from part to part (or batch to batch?)
14 Oct 10 10:49
sorry...forgot to say...."its a Latching solenoid valve"
14 Oct 10 11:06
I wouldn't say DC. If this is the latching coil you have discussed in other threads, the time spans involved are tens of milliseconds. That implies frequencies in the tens of Hz range and there, the ESR is essentially the same as at 120 Hz.
Also, it will have a very small effect on your circuit's performance. I think it would be a lot more productive to concentrate on real issues.
Gunnar Englund
www.gke.org
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
