Strand7 import from Patran
I am interested to see if Strand7 can import file create by MSC.Patran. In Patran I have the option to export as *.out but in Strand7 I only have the option to import *.nas or *.dat. I am wondering if anyone knows the way around this?
Thank You
JBeng00
Thank You
JBeng00
RE: Strand7 import from Patran
I think that you can only transfer a FE Model from Patran to Strand7.
To do this under Analysis menu in Patran and press OK on Analyze - Entire Model - Model Only
This will write a File in the Patran working directory . The file will have the name of current Job and an bdf extension.
Now rename the file as *.dat extension and try to import in Strand7, it should work!!
If you just rename the file as either *.dat or *.nas, you should be able to import it into Strand7 OK.
Hope this helps!
Also note that there is a Strand7 section here:
http://eng-tips.com/threadminder.cfm?pid=1267
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
