Unable to do calculations in Modify Dimension Dialog
When entering a dimension value in the Modify dialog, I can enter "1/2" for a .50 dimension, but I can not perform any other calculation.  I get the error "Please enter a number between XXXXXXX and YYYYYYY".  I am also not able to enter Equations.  No matter what I try (including "TEST = 1") I get the error "Equation entered is invalid".
It seems as though the math function is turned off or something.  Any ideas?
TIA,
<tg>
Please see FAQ731-376: Eng-Tips.com Forum Policies before flagging posts.  Per line item #4, some cross posting is appropriate when done correctly.
RE: Unable to do calculations in Modify Dimension Dialog
Uninstall/reinstall didn't seem to solve it.  Starting to suspect an x64 vs x32 issue.  Now running on 64bit Vista.
You don't mention which version of SolidWorks you're running or whether it's 32-bit versus 64. Those pieces of info will help us a little.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
I was afraid you'd laugh.  I am running an old copy of 2001plus.  I had it loaded on my old laptop (32-bit Windows 2000) and at some point the calcs stopped working.  I think it was after some 'essential windows update'.  Fast forward.  I now have a new laptop running 64 bit Vista.  I had a couple of side jobs pop up so I loaded my 2001plus on this new laptop.  The calcs still don't work.  And this job requires some equations to generate a complex curve.
Hmmmm..... Yes the SW2001Plus on a Vista system could be the problem.
Not sure any of us can help you with such an old version of SolidWorks.
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2011 PR1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
What Anna said...
I suspect you'll run into other problems as well.
Jeff Mirisola, CSWP
M9 Defense
My Blog
As a work around, can you insert a design table, and define the equations in Excel?
Eric
Thanks for the feedback.  Since it was working and then stopped working on my old laptop, I was hoping it was fixable.
I've never used design tables.  I'll give that one a try.  I bought this seat to do some contract work years ago.  Since then, I've been full-time with 3 different companies that all used ProE.  I prefer SolidWorks but just haven't used it in about 7 years.
<tg>
From the SW knowledge base on that error:
Quote:
Question:
When trying to do a math operation, a + or – in a dimension box, an error displays saying, "Please enter a number between 0 and 39370.079." Why?
 Answer:
This is most likely caused by corrupt or incomplete VBA components on the system. Please insert a SolidWorks DVD and browse to the <Drive>\PreReqs\VSTA folder and run vsta_aide.msi
Please install these components if they are not already installed or choose repair. If this does not address the issue, please create an Rx of this problem and contact your local support representative.
I would try the DVD solution, its the easiest one to perform.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Thanks Scott.  I tried re-installing several times over the weekend.  I even tried a safe-mode install.  When I did, I actually got a error message relating to the VBA install.  No doubt my 2001Plus disks know nothing about Vista, but maybe I can find a similar folder and can manually install.
<tg>
Nor does SW2001 know about VSTA as it did not exist then.  VSTA is not Vista the operating system. It is Visual Studio Tools for Applications.
That KB article does not apply for your vintage version of SW.
Anna Wood
Dang I missed the version in the post... 2001 is far to old to run on today's machine and have their own set of problems because of it and there is no support for that version.
I would recommend upgrading to 2011 and then you have near the issues you are experiencing today.
Berry Plastics
www.scottjbaugh.com
I would suspect it's not a legal copy of the software.  Your best bet might be to get an old Pentium with Win 2000 on it.  The other problem you might encounter is the support for MS Office.  You'll likely need to find an old version of that as well.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
No, it's definitely a legal copy.  That's why it's still on 2001 because I'm too cheap to keep up the mainenance.  LOL  And as I mentioned, I was running on Win 2000 and had the same issue occur after an update so I was suspecting software/configuration and not hardware/OS.  And it may surprise you, but otherwise, I know of no issues.  It runs great on Vista.
But I agree totally, it is time for an upgrade...
<tg>
You can pay your maintenance late and just get a late fee of $500.00 or so charged and access all the versions since 2001+. You probably won't recognize the software due to all the new improvements and new Command Manager.
With some other systems you need to buy the full license all over again and they force you to pay maintenance.
Michael
Thanks Michael.  Sounds like I need to track down my salesman and see what I can work out.  It might not be as bad as I thought it was.
<tg>
