Start up Ansys 6.0 seems to hang
Hallo everyone,
After I started up "Run Interactive Now", it takes long time (at least 5 minutes) to run apllication.
Do you know, how I may speed it up?
I'm using ANSYS 6/ANSYS 6.1 on WINNT4 and Windows 2000 - the same problem.
Thank you in advance
Mai Romberg
RE: Start up Ansys 6.0 seems to hang
It depends only on your computer. Probably, you need to upgrade it or to buy an extra RAM. You can also increase the memory buffer to 128 & 64 MB respectively in INERACTIVE startup, close any other applications ect. Check "memory management" chapters.
