Windows 7
Windows 7
Windows 7
Is anyone running SW 2007 on the Windows 7 platform right at the moment we are using XP with no problems.
RE: Windows 7
I have not tried SW2007.  But I have tried with SW2008 and did not have good results.  I would expect Win7 to not work with SW2007 very well either.
You could run in Windows 7 Virtual PC mode, but you will need the Pro version of Windows, not the Home version.  SW will run dog slow in Virtual XP mode.  I have tried that as well for SW2008.  Not an option for real work.
http://www.microsoft.com/windows/virtual-pc/
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2011 PR1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
RE: Windows 7
I've been running SW 2010 x 64-bit OS on Win7 Pro for about 3 months without any problems.
RE: Windows 7
The OP was concerned about an environment not supported by SW, ie., W7 with SW2007.
I have not had problems with SW2009 and W7, but SW2010 on W7 Home has been a struggle with many crashes of SW and the Windows system.
"no visible means of support"
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
