Good Tip for a strange situation with substract NX7.5
Hi everybody
During my last session NX7.5 with the substract function it was impossible for me to select the tool body. The unite function was possible.
I created a sample example to reproduce the problem with a block and a cylinder (have a look at the video)
I found the solution by using the reset button !!!
Didier
RE: Good Tip for a strange situation with substract NX7.5
That looks like something you should report to GTAC, if you haven't already done so...
I was not able to reproduce the problem using version NX 7.5.2.5 (which will be the next MR released in a few weeks).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
In fact, I have able to reproduce in the same NX session and after reset the problem disappeared. Then I logged an IR to gtac (same number than the video file).
By this post I wanted only to explain the solution if anybody will be in the same situation
Didier
I juste received the answer from gtac. A similar problem may exist in assembly with some face unselectable and the reset buton was the solution.
