FOS defined with basic dimensions... legal?
If I have a cookie-cutter shape that I want to define with basic dimensions and use a profile tolerance, can two parallel and opposing flat surfaces in that profile be used as a Feature Of Size?
It seems to be that it could be, as the size it the basic dimension with the tolerance applied from the profile FCF.
Is this correct?
RE: FOS defined with basic dimensions... legal?
I believe so.
Frank
dtmbiz,
This is a ticklish one, particularly in Y14.5M-1994.
I would imagine that the purpose of this is to use the two opposing surfaces as a datum feature at some material condition.  In '94 material conditions were only defined for features of size and to meet the '94 definition of a feature of size, the feature must be associated with a size dimension.  So the profile tolerance alone won't get you there.
Could a size tolerance be applied to the parallel-plane feature and coexist with the profile tolerance?  I don't see why not.  The profile tolerance would just have to be a refinement of the size tolerance.  If the size tolerance had the same bandwidth as the profile tolerance, then it would work because the size tolerance would allow more variation at LMC.
Jim, JP, others - opinions?
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
Yes Evan this is the exact phraze that got me to wonder if it is or isnt?
What is is? (:
Anyway what is "size"? A basic dimension is a theoretically exact value, where as, in a sense, it could be argued that a non-basic dimension without a tolerance is theoretical exact value. The traditional "size" dimesion would have a tolerance attached to it or default to a general tolerance, while the basic dim has its tolerance in a FCF.
Just thinking about possibilities.
This is ticklish even in the 2009 standard, Evan!   It drives me nuts, but the definition of a feature of size says that it must be "a directly toleranced feature" (para. 1.3.32).
I can't recall if this came up in another thread, but because of this definition, you can't just point to a hole or pin and call it a FOS.  In order for it to be a FOS, it must be directly toleranced!
And that brings up the definition of "directly toleranced."  If I give a distance of 20 mm but leave it to the title block for the tolerance, I would say that it is not "direct."  Same for the OP where the distance is a basic dimension.  Or do you guys think that the profile all around qualifies as "directly toleranced"?
John-Paul Belanger
Geometric Learning Systems
Sorry, one other comment...
Evan, I would say that you can't have a size tolerance be applied to the parallel-plane feature and coexist with the profile tolerance.  That's because the standard requires profile to be applied to a "true" profile, which in turn mandates basic dims for the surface.
John-Paul Belanger
Unfortunately we are stuck on the 1994 standard.
I don't see a problem using opposed surfaces as a datum feature ... note NOT a datum fos.  As indicated above, the tolerance must be directly applied (i.e. applied to the dimension, not the feature).  In this case, referenced at RMB (RFS) would get you the center-plane based on the two opposed surfaces, though which one would dominate without a reference to a higher datum precedence could become a point of contention.  '94 does not specify that only FOS can be used to establish a datum center plane, though it doesn't give much guidance otherwise.
Using an irregular datum feature controlled by a profile control is now included in the standard ('09) as an irregular datum feature (See Fig. 4-3).  You can also now reference a planar datum at MMC in the datum reference frame ... another topic for another day.
As for the question of whether a general linear tolerance block would make an undimensioned (non-basic) dimension a FOS, it would depend on whether or not the feature has directly opposed points; the tolerance is considered to be applied directly to the dimension and so that aspect is already met.
I believe that the missing link here is that the standard requires a directly toleranced "dimension", not a directly controlled feature which is what you must have when you use basic dimensions to describe the nominal geometries.
Jim Sykes, P.Eng, GDTP-S
Profile Services  www.profileservices.ca
TecEase, Inc.  www.tec-ease.com
JP,
Yes, you're right.  We need basic dimensions for the true profile.
I hate to bring this up because I object to it, but there are examples in the standard in which profile is used along with a directly toleranced dimension.  There's a figure where the line profile tolerance ends up acting like parallelism, I think.  The usual location-controlling aspect of profile is magically overridden by the presence of the directly toleranced dimension.  It's horrible.
Evan Janeshewski
www.axymetrix.ca
Ah yes...   Just as position used for orientation only is my pet peeve, Evan has this one.  It was brought up in a thread many months ago and I think we all just kinda threw our hands up and said that the picture violates the letter of the law for profile.
It's Figs. 8-17 and 18 in the new std.
John-Paul Belanger
Jim,
I don't have the standard in front of me, so I can't give any specific figure or page numbers.  I think it's near the end of the profile section.  The part has a flat bottom and a curved top, and there's a line profile tolerance.  The directly toleranced dimension lets the height float within a larger range than the profile tolerance would otherwise allow.
Evan Janeshewski
www.axymetrix.ca
Not sure it's really a conflict.  The toleranced diameter is at one point only (rather useless in my opinion) while the profile controls the entire surface.  It's grossly along the same lines as two single-segment position controls wherein the second is a refinement of location as well as other stuff.
Jim,
Are you talking about the figure with the conical part?  That isn't the one I was thinking of, but it has a similar problem.  The profile tolerance would usually control the "size" of the cone, but the presence of the directly toleranced dimension somehow overrides that.  The profile tolerance ends up acting like a total runout tolerance.  This example is even more horrible than the other one I was thinking of.
The other example is right near the end of the profile section in 2009, I think.
JP,
I wish that this was my only pet peeve with Y14.5.  It is a big one though.  I also have the self-referencing datum feature, the "datum axis" established by hole pattern, the wildly inconsistent use of the term "datum plane", two "interpretations" for position tolerances, the list goes on ;^)
Evan Janeshewski
www.axymetrix.ca
Evan,
You might be thinking of Fig. 8-27 of the new standard, with a flat top and flat bottom.  But what you describe is actually OK, because profile is not controlling the location; it's only controlling orientation to the datums (and form, of course).  IOW, FIg. 8-27 is exactly equivalent to using angularity with "each element" noted below it. Thus, no conflict with the size dim.
But I had thought you were referring to the examples of profile on a cone...
Jim,
The standard says that a profile tolerance is applied to a true profile.  A true profile is defined as perfect, and given by basic dimensions (or CAD data).  So are you saying that in Fig. 8-17 the "profile" is still true because profile is translated as "shape only"?    (Yet the size is not "true.")
John-Paul Belanger
I will put my 2 cents worth in this discussion.
Fig. 8-25 of the 2009 standard has an irregular feature of size with a profile tolerance controlling the form and a positional tolerance controlling the location. The complete irregular shape is a feature of size.
Could we separate 2 parallel surfaces in this example and call the enclosed space a feature of size? I think that 1.3.32.1 covers features of size of "set of two opposed parallel elements or opposed parallel surface, each associated with a directly toleranced dimension. See par. 2.2"
Par. 2.2 (a) Limit dimensioning
         (b) Plus and minus tolerancing
(c) Geometrical tolerances directly applied to features.
To sum it up - I think that 2.2 (c) covers the question and a yes may be appropriate here.
Dave D.
www.qmsi.ca
Re Fig. 8-27, J-P is right that the profile of a line controls the orientation & form as a refinement of the location already established by the fos dimension.  It's a hierarchy-thing; first thing, a feature must be located if it can be, then it can be refined for orientation & subsequently for form.
Fig 8-17 has a basic angle defining the conical surface, and a linearly-toleranced dimension controlling the size at the one end alone.  From whatever acceptable size that diameter is produced at, a "perfect" cone of 15-deg included angle is established and the surface is then controlled based on the profile control.  Leaving them as a basic dimensioned width though ...
Fig 8-18 is a little bit different, but similar.  The toleranced diameter sets a zone within which the single cross-sectional diameter must lie.  The basic 15-deg conical profile zone can float within that linearly toleranced zone at that specific location.  I have seen this used (poorly) as a datum target line; they way it was done didn't work very nicely.
Dave...hmm.  Definitely the entire outer path establishes an irregular feature of size.  If you changed the 50.8 dimension from basic to linearly toleranced, then it is mostly a feature of size (the two sides are not 100% directly opposed as they are of different lengths); perhaps again an irregular feature of size?  From 2.2, indeed if basic 50.8 dimension remains, then the profile control is now considered a directly applied tolerance ('09) and the width can indeed be classed as a feature of size.  Tks for pointing that one out.
JP,
Yes, it is Fig 8-27.  I still don't like it.  To me, profile controls size if it can and controls location if it can.  This is one of the things that distinguishes profile tolerances from orientation tolerances and runout tolerances.
Perhaps what irritates me is the "oh by the way, here's how it works in this case" way in which these examples are presented in the standard.  Here's the explanation of Figure 8-27 on page 176:
"Figure 8-27 illustrates a part with a profile of a line tolerance where size is controlled by a separate tolerance.  Line elements of the surface along the profile must lie within the profile tolerance zone and within a size limiting zone.  In this application, the datum references only orient the profile of a line tolerance."
So in this case the datum references only orient and we don't need basic dimensions to define the true profile?  Where the heck did that come from?  Now I have to hunt for a dimension to see if the profile tolerance controls location relative to the datum feature (they call it size)?  Good grief.  See, now you got me started on the "profile with size" thing.
I wish that Y14.5 would explicitly adopt underlying concepts, and stay consistent with them.  Instead of implicitly adopting underlying concepts, and subverting them by including non-rigorous exceptions for specific cases.
Evan Janeshewski
www.axymetrix.ca
I've never seen a problem with profile floating within a ± tolerance if we only desire form and orientation.  Just seeing that the location is not basic is enough to realize that profile doesn't cover that quality.
But this cone picture has me bothered -- how can a circle/cone/sphere have "true" shape but retain a toleranced size?    Wouldn't you rap the knuckles of someone who attaches profile of a surface to a hole if there's a size of Ø10 ± 0.2 on the same hole?
John-Paul Belanger
Yes, BUT a hole's (or sphere's) size (i.e. overall, not just at one point) can be controlled with a linear tolerance whereas a cone's size overall cannot be controlled by linear tolerances.  Therein lies the difference.  And yes, I do like to rap knuckles.
JP,
There are those on the committee who feel that, if a size tolerance were present, a profile tolerance would only control the form of a cylindrical hole.
Here's another reason I don't like these examples that mix profile with a size tolerance.  In almost all other cases in Y14.5 (DML straightness overriding Rule #1 notwithstanding), a geometric tolerance must refine what is already provided by other controls.  But in 8-17, 8-18, and 8-27 the presence of a size tolerance un-refines (coarsens? overrides?) the control provided by profile.  The control provided by profile depends on the presence (or absence) of a directly toleranced dimension.  This just does not sit well.  It doesn't lend itself to MBD, that's for sure.
Evan Janeshewski
www.axymetrix.ca
Let me stretch the analogy further.  If some on the committee believe that it's OK to profile a hole that has a ± diameter, then I could make the same case for a radius curve.   After all, a single radius is merely a portion of a circle, right?
Please tell me the committee would not allow something like R 13 ± 0.5 to then have a profile tolerance!    Of course they wouldn't, because it's not a true profile.    Ergo, I say same for a hole.
Evan, I don't see the difference between these two statements:
--profile must refine what is already provided by other controls such as size
--a size tolerance un-refines the control provided by profile
To me that's like saying "New York is east of Chicago, but Chicago is west of New York."
John-Paul Belanger
JP,
I'm not sure what they would say about the radius suggestion.  Probably something like "well, a radius is not a feature of size, so profiling it would be ridiculous" ;^)
It looks like my bitter rant about "un-refining" didn't get the point across.  If a smaller tolerance A refines a larger tolerance B, the larger tolerance B does not un-refine the smaller tolerance A.  I'll try the explanation again before I've had too much coffee.
Back to Figure 8-27.  If the 80 was a basic dimension, the profile tolerance would control the location of the surface within a zone 0.07 wide.  In other words, the height relative to datum A would be controlled within 0.035.  Because profile controls location.
But if we change the 80 to a directly toleranced dimension, the height is controlled within +/- 0.2.  Suddenly profile doesn't control location anymore.  The addition of the size tolerance has "un-refined" the control that would have been provided by the profile tolerance.
This is not how combinations of geometric tolerances and size normally work.  If I have a cylindricity tolerance of .005 and a size tolerance of +/- .010, the form of the cylinder is controlled within .005.  We don't "un-refine" the cylindricity to .020.
Is that a better explanation?  I suppose that the opposing argument is that profile only controls location (or relative location) if the true location is defined by basic dimensions.  By the same token, profile only controls size if the true size is defined by a basic dimension.  Does this mean that profile only controls orientation if the true orientation is defined by a basic angle?
Evan Janeshewski
www.axymetrix.ca
Your last paragraph is right on target: Profile only controls location (or relative location) if the true location is defined by basic dimensions.   Profile doesn't automatically control location just because a datum reference is invoked.  Perhaps the standard doesn't state this outright, but because profile is a hodgepodge of several things we have to be careful to look at the dimensions to see what to extent the profile controls things.
So maybe say it this way ...  a datum reference in a profile FCF means that we are tolerancing some sort of relationship with that datum.   The "lowest-level" relationship of a surface to a datum is orientation.  So that's what Fig. 8-27 is saying.   However, if the height were changed to a basic dim, then we'd be controlling orientation and location (and of course size, too).
That said, I still don't follow the analogy about unrefining something.  If two things control something, then the tighter one takes precedence.  But the other thing can still control a broader characteristic.
Sorry if we deviated far astray from the OP.  But I'm having fun anyway...
John-Paul Belanger
Exactly right, J-P.  It's the hierarchy again.  Location first, orientation second, form third.  If a feature can be located, it must be located.  In 8-27, the top surface is located by a +/- tol from the lower surface (or vice-versa).  Now that its location is defined, the lower level functions of orientation and form can be refined ... note, no unrefinement.
You guys are right, the effect of profile depends on the presence of basic dimensions.  That's how they did it in the standard.  I guess I just wish that it was some other way, because there is all sorts of ambiguity when you bring in implied basic orientation, MBD, etc.  It might also be that I'd rather not have the size characteristic being mixed into everything.  Size is such a nasty characteristic when you try to put rules on it.
Here's a question.  Imagine a garden-variety position tolerance for a single cylindrical hole, with the standard three-plane ABC datum structure and basic X and Y dimensions showing true position.  Now change the basic dimensions to directly toleranced dimensions.  Does the position tolerance now control orientation only?
Evan Janeshewski
www.axymetrix.ca
You guys know my feelings on that one  :)
The very word "position" means that there is some sort of distance involved.  So while orientation is one aspect of position, the position symbol must [u]always[/i] have location leading the caravan, as it were.
John-Paul Belanger
JP,
That's kind of the way I feel about profile.  That it must control size if applicable, and must control location if applicable.
I guess I just want the profile zone to behave in a consistent way.  I want the "magnitude" of the profile zone to remain fixed, so that it can't grow and shrink like a cylindricity or total runout zone.  This takes care of the size control.
I also want the orientation and location of the profile zone to be constrained to the datums that are referenced.  So that the location doesn't float like a parallelism zone.  This takes care of the location control.
I believe this is the underlying logic of how profile zones work when basic dimensions are used.  It's just subverted when the darned size tolerances are mixed in!
Evan Janeshewski
www.axymetrix.ca
Well, let's go to the standard:
Paragraph 7.2 says that the position symbol involves "the location of one or more features of size."  That's why I say using position for orientation-only isn't possible; it would be missing the constitutive element of the symbol.
But Paragraph 8.2 says that the profile symbols control "form"  or "combinations of size, form, orientation, and location of a feature."  That's why I say profile need not have location as part of the package; form might be the only thing profile does in certain cases.
John-Paul Belanger
OK, in essence then, we are all agreeing that (1) position SHOULD NOT be used as an orientation-only control <legal or not, it's a bad practice>, (2) profile should be used in as robust a means as possible, controlling as many of the feature's aspects as it can.
I've read several trainers' materials and could never understand why some of them have written things as being "law" when in fact it's just their personalized "best practices".  I talked with some and heard it was because trainees miss the subtleties of "must", "should", "should not" and "must not".  I was dubious until a year ago when I heard feedback that a trainee had taken what I'd described as "technically" correct but poor practice as the gold seal on the practice.
