Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It's fun to see others going through the same stuff I did and be able to help. It's also a way for me to stay sharp and not lose the stuff I've learned..."
Geography
Check valve leakage rate basis/philosophy for PSV sizng
compo (Chemical)
13 Oct 10 12:24
I am trying to get feedback from the wider industry on the basis/philosophy considered/used for establishing the leakage rate back through check valves in view of calcualting required relief valve size to protect the upstream section the check valve is leaking into, this is specifically the case where two check are provided in series and one is considered to have completely failed and the other has a leakage rate based on for example a) ?? percentage of forward flow or b) ?? fraction of check valve rim face or area or c) any other basis.
I am sure many design and operating companies follow varying philosophy, if you can help and share your experience and company standard and / or point me in a direction of a guidance document or paper you may know of such as a international standard. Thank you all in advance for any guidance you can afford.
Chance17 (Chemical)
19 Oct 10 22:47
one major oil refiner allows evaluation at 10% of forward flow.
Close Box
Join Eng-Tips® Today!
Join Us             Close
