Amp for signal generator
I wish to amplify sine wave from a signal generator 10Vpp 50 ohm load, 0.2 amp pp up to 1 amp pp for a test.
Running 0-10kHz.
Just like to build a simple circuit rather than buy expensive instrument. Might learn something.
thanks in advance
Running 0-10kHz.
thanks in advance
RE: Amp for signal generator
Or, if you choose to build, use one of those hybrid power opamps.
But you still have the 0 - 20 Hz gap.
Gunnar Englund
www.gke.org
I need to drive 1 amp total peak to peak. About 20 ohm.
thanks
Gunnar Englund
www.gke.org
http://waltjung.org/PDFs/WTnT_Op_Amp_Audio_2.pdf
http:/
Gunnar Englund
www.gke.org
The Bill Marsden circuit with 2N2222 and 2N2907 might be hard pressed to deliver the necessary power output.
Gunnar Englund
www.gke.org
The numbers we have seen so far indicate that the OP is a mechanical guy - which his handle also says.
Gunnar Englund
www.gke.org
Off-the-shelf audio amplifiers might be ideal in such cases. They're typically designed with good current driving capacity to keep the woofer cone under control.
http://www.national.com/cat/index.cgi?i=i//277
Benta.
Can probably be found on eBay for an easy price.
Gunnar Englund
www.gke.org
http://www.cirrus.com/en/products/pa07.html
