Pressure sustaining valve for wastewater effluent application
I'm looking for a pressure sustaining valve for use in a force main transporting effluent from a wastewater collection system. The wastewater contains low levels (20-30 mg/L) of low density suspended solids (in other words, "floaties").
The valve needs to maintain +/-15 PSI on the inlet while passing flows of 0-100 GPM. The valve should close if the inlet pressure drops below the set-point, and fully open when the inlet pressure exceeds the set-point.
A valve similar to this:
http://www.controlvalves.com/series/108/index.html
would be sufficient. But I've talked to a few reps and they have said they are not suitable for use with wastewater. I'm not sure if they equate wastewater with high solids sewage, or if the low level of suspended solids actually presents a problem for that style of valve.
Thanks in advance for any of your input or suggestions!
RE: Pressure sustaining valve for wastewater effluent application
