toolpath replay different in NX7.5 than NX6
In NX6 when you replay a toolpath it stays displayed until you refresh. In NX7.5 when when you replay a toolpath then replay another the 1st one disappears. You can highlite multiple toolpaths in NX7.5 and they will all display but not one at a time. What's up with that? It is useful to have the NX6 behavior. Anyone know a setting or workaround.
RE: toolpath replay different in NX7.5 than NX6
1st.
Preferences -> Manufacturing -> Tab User Interface, now in the Operation Navigator section, switch off both options:
- Display Selected Objects and Display Turning IPW...
2nd.
Preferences -> Manufacturing -> Tab Operation, now in the section Tool Path Replay switch off Refresh before Each Path.
If You want the same behavior when create, switch off Refresh before each path in the Tool Path Generation section.
Hope this helps.
Frank.
Thanks Frank
