Material Properties as Parameters
I want to show items from my materials list as parameters. I can get things like density using DEN=MATERIAL_PARAM("MASS_DENSITY")working, but I can't get the material name to work as a parameter.
Does anyone know how this can be done.
Hayden
RE: Material Properties as Parameters
Hello Hayden,
Use the following syntax:
MATERIAL = MATERIAL_PARAM("BEND_TABLE")
Note that you must fill in the material name (ex: Al-6061) for the BEND_TABLE field in the material file. No spaces are permited!!!
-Hora.
Thanks Hora, I've done that.
Do you know if any extra fieldscan be added to the material parameters list?
Hayden
