Question regarding feeder to receptacle
Does anyone see an issue with supplying a receptacle rated for 50A, 125/250V, 3-pole, 4-wire with a 50A 120/208, 3phase, 4-wire feeder?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Question regarding feeder to receptacle
The 208/120 3 phase , 4-wire system has three hots, one neutral and no ground. (NEMA 18-50R plug).
You will end up putting 120V on a pin that is designed for the grounded neutral conductor. That could be dangerous to someone in the future. It might be safe, depending on how the plug connected equipment is connected, but it probably isn't.
Best to use the correct plug if you need 3-phase power.
But if you only need single phase power, wire the plug with two hots, a neutral and a ground. The only difference will be the hot pins will supply 208 V instead of 240V. Hot to neutral will still be 120V and the ground will be connected.
If in fact you intend to supply a "120/208 3 phase" (3 hots and a ground) load via such a receptacle, I have several reservations, the most significant- where do you put the 3rd hot? Use what would normally be the neutral terminal for a 120 volt lead? Not me.
There are several other NEMA receptacles that are more suitable, even a twistlock 4 pole 5 wire configuration if you want to run both neutral and ground to your receptacle; NEMA L21-50R and L21-50P respectively.
