what is the meaning of "No Loop Or Do Not Pocket"?
No Loop Or Do Not Pocket in terms of pipelines - are they same meaning? in that case why used in different occasions? Pls. clarify
RE: what is the meaning of "No Loop Or Do Not Pocket"?
It applies to liquid lines as well. You slope the line to the point it is supposed to drain to.
We've got what a pocket is.
Adding an expansion loop does not necessarily mean creating a pocket, but if you can't flat turn a line out of the rack there will be a pocket (i.e. if you're trying to loop a line sandwiched between other lines, you got to go up and over more than likely).
Why would a P&ID declare "no loop"? I have to guess... maybe because the line is very sensitive to pressure drop or a turn might separate a mixed flow?
I've only seen "no loop" on P&IDs produced by a ChemE "process engineer." I haven't seen such a note by a M.E.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
