Material Compatibility Issues Subsea Flanges & Fittings
Could anyone provide any guidance on any material compatibility issues with specifying A453 Grd660 fasteners for use in a marine environment on Inconel Alloy fittings? I have checked the coefficients of expansion and there isn't a major difference so I wouldn't of thought this would/could lead to excessive bolt stresses or  flange connection integrity issues.
RE: Material Compatibility Issues Subsea Flanges & Fittings
SAE J2280 SHIP SYSTEMS AND EQUIPMENT—FASTENERS—SELECTION AND IDENTIFICATION REQUIREMENTS states that nickel alloy components that are submerged should be joined with fasteners composed of the following materials:
NiCu Alloy 400/405
NiCuAl QQ-N-286
Alloy 625+
Alloy 725
Titanium
ASTM A 453 Grade 660 fasteners are not suitable for this application for a several reasons.  First, galvanic compatibility with Ni-based alloys in seawater is not good.  Second, without cathodic protection (CP), Grade 660 (also called A286, X5NiCrTiMoVB25-15-2, or 1.4606) is susceptible to pitting and crevice corrosion in subsea applications.  Ni-based alloys like Alloy 625 or 725 are high strength fasteners that are suitable for subsea use without CP.
there will be CP provided, however it sounds like i'll be better going with something else. is there a reference for the galvanic compatibility issues? i read in ISO 10423 that A453 Gr 660 fasteners are good for use across the board for subsea use. thanks
JT100,
I assumed that CP was not being used based on the materials you mentioned, which was obviously a bad assumption on my part.  As long as the full length of the fastener will be exposed to CP, then ASTM A 453 Grade 660 is acceptable in contact with Ni-based alloys.  In addition to ISO 10463, heere is an article that discusses the topic of fasteners for seawater use, galvanic coupling, etc.
http://namis.alionscience.com/conf/tscc/search/pdf/AM022833.pdf
JT100,
The SAE document I referred to shows Grade 660 as compatible with nickel alloys in wet environments, but not compatible for submerged conditions.
