High Temperature Purge Dam
Is anyone aware of any soluble purge products that will withstand elevated temperatures, i.e 600°F minimum?
We have a closure weld at a nozzle that must be back-purged, and the nozzle is not of sufficient length such that we can get a paper purge in without burning up the dam. Being a closure weld, there is no access to remove any sort of inflatable bladder.
RE: High Temperature Purge Dam
Past that, thin sheets of stainless steel or even aluminum foil. You may need an origami expert to help you get a reasonably shaped shield/dam through the nozzle outlet and back out again...
Or am I misreading what you are doing?
Why can't you use a small steel tube with backing gas applied to the weld root region through a window 180 degrees of where the welder is pulling the root? Seen it done many times in the field. Granted you will have a small region where backing gas will not be applied when you close the window. However, this is a small region and should not pose a problem.
Met: That may in fact be our only option. Unfortunately, our material is P91.
Just remember that the majority of purge problems is too much flow on the gas side. It doesn't take much gas to purge a weld.
If your specifications will allow different approaches the links below will show a cross section of what's available and if nothing wlse keep them in mind for future purge problems.
You haven't mentioned the size or material, but maybe able to use a non-noble gas in the system.
What's available
http://w
Backing rings and consumable inserts
http://ww
http://www.robvon.com/
Ceramic backing rings
http://www.cerbaco.com/index.html
variations on a theme
http://www.aquasolwelding.com/
Mike Halloran
Pembroke Pines, FL, USA
Try a teflon dam made in 4 pie-slices and secured with metal foil tape, as far from the weld as possible. May need 2 dams, one on each side of weld. Tie the segments together with wire, and attach a pull-wire to collapse the dam(s) and extract them. Take care not to melt the pull-wire.
