Change Model View to use
I created a drawings with an ISO view with annotation and dimension.
Now, for better understanding I need to create a little exploded view.
If I go in the model of the specification and I create a exploded view with saving, can I edit the ISO view and select the exploded view ?
Thank you...
Using NX7.0 and TC8.1
RE: Change Model View to use
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I created the 'exploded view' in the same file where the drawing exisits, but when I edit the ISO view I can't able to reassign other view.
Maybe you tell me that it's not possible when you write '....
you can NOT bring an exploded view in from the model file'.
My English is basic.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
I'm in the Master Model mode.
I have an exploded view in the assembly with turn off the Drawing.
When I turn on turn the Drawing and I add a new view I can select my exploded view, but I'm asking if it's possible to edit a before ISO view, reselcting the exploded view.
I add a lot of annotation and dimension, I don't would like to delete it.
Thank you...
If that is indeed the question, the answer is "No".
John R. Baker, P.E.
Industry Sector
Cypress, CA
I understand now.
Thank you...
