Capacity of 2-ply gypsum board shear walls
Ok, so I need to calculate the capacity of wood framed shear walls clad in 2 plies of 1/2" gypsum board on each side of the wall. These are interior shear walls between condo units. I had specified 5/8" plywood on one side. The architect wants me to consider the capacity of the 4 plies (total) of gyp board. But I can't find anything which really helps me here. All the tables I can find are one ply on one side of the wall.
can anyone point me in the right direction?
RE: Capacity of 2-ply gypsum board shear walls
Moreover, it does not permit gypsum wallboard to carry 100% of the applied shear. The percentage permitted depends on the number of storeys, i.e. for a 3 story building, gypsum wallboard shearwalls can carry 80%, 60% and 40% of the shear in the 3rd, 2nd and 1st storey respectively. The remainder must be carried by wood panels.
BA
Probably the best you could do to get a value without adding a wood structural panel, changing your stud spacing, and going blocked, would be to use 5/8" on both sides and have your edge nail spacing at 4". This would at least give you a nominal seismic and wind value of 580 plf.
You can always email the American Wood Council, who make the NDS, and explain your particular situation. Their website is www.awc.org
