Transparency issues in assembly
I am putting together an assembly, and for some reason or another, I now am unable to make parts transparent. They all went grey, even though some were blue and red etc. When i click change trans., it simply takes the lines off of the part, leaving just shaded with no lines. But alas, no transparency. What has happened and is there any way to fix it? It is not essential, but very helpful.
RE: Transparency issues in assembly
What SW version and video card?
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
2 - Are you using an approved card?
3 - Is this a new problem, or has it happened on other assemblies?
4 - Have you recently upgraded SolidWorks?
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
the assembly changes the color scheme from the default config to the new config, even though I didn't choose any different visual aspects....why does it do that? I can make anything I want trans. in the default configuration, and nothing in my new configuration. All I changed was one part. And i do not know if it happens in other assemblies, this is my first attempt at using configurations, and i think I will abandon this if it continues to present issues. Thank you for your help!
