Missing Open Dialogue Box Acad 2007
I've come across an issue I can't seem to resolve.  I'm using Full AutoCAD 2007 and when I use the FILE > OPEN command it acts like the dialogue box is open but I can't see it on either screen.  I can not select any other option from autoCAD at this point and when I do try to click a command in autocad I hear the windows critical stop "ding"
Here are some of the steps I've tried:
  1. Moved settings and sides for the screens in the ATI control panel.
  2.  Removed & Reinstalled updated video drivers and ATI control Center.
  3. Repaired registry on Acad from Add/Remove
  4. Repaired Acad from Add/Remove
  5. Uninstalled/Reinstalled Acad
  6. Verified FILEDIA is set to 1.
  7. Verified CMDDIA is set to 1.
If I try FILE > NEW, NEW SHEET SET, OPEN SHEET SET, all dialogue boxes appear.  I'm thinking my next step is to blow away this users profile and start  him from scratch but I'd rather see if there's a quicker, more painless for the user solution.
Angus
RE: Missing Open Dialogue Box Acad 2007
Change so the main window does not fill the entire screen.  Do a File-Open and look for the dialog.  Try Alt-Space then M then use your cursor keys to move the dialog a long way in one direction - maybe it will appear.  If not, try another direction.
Try this:
Click on File | Open.
Right-click on the Taskbar, click on Cascade Windows.
This should pull your Select File dialog box to the upper left of your screen.
Ralph
Structures Consulting
Northeast USA
Thanks for the ideas, I did try the Alt-Space M with no luck so I just replaced the user profile with a default one and everything worked fine after that.  I didn't get a chance to try the cascade.
